Robustness of a routing tree for the Push Tree Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
The Push Tree problem contains elements from both the Steiner Tree and Shortest Path problem. It deals with the trade-offs between the push and pull mechanism used in information distribution and retrieval. In , a two step approach for the Push Tree Problem was proposed. In the first step, a «good» spanning tree (called routing tree) is constructed and then the problem is solved in this particular tree. Finding a routing tree is NP-hard but the second step may be performed easily, thus the idea is to use the routing tree as a (semi-) stable infrastructure and to perform adaptations to changing information patterns inside the routing tree. In this paper, we study the robustness of a routing tree when the information requests disappear at some nodes.
Autre [cs.OH]
RR-4464.pdf (171.01 Ko) Télécharger le fichier
inria-00072124 , version 1 (23-05-2006)
  • HAL Id : inria-00072124 , version 1
Frédéric Havet. Robustness of a routing tree for the Push Tree Problem. RR-4464, INRIA. 2002. ⟨inria-00072124⟩
87 Consultations
71 Téléchargements
