Ontology Engineering: a Survey and a Return on Experience - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
Ontology is a new object of IA that recently came to maturity and a powerful conceptual tool of Knowledge Modeling. It provides a coherent base to build on, and a shared reference to align with, in the form of a consensual conceptual vocabulary, on which one can build descriptions and communication acts. This report presents the object that is called "an ontology" and a state of the art of engineering techniques for ontologies. Then it describes a project for which we developed an ontology and used it to improve knowledge management. Finally it describes the design process and discuss the resulting ontology.
Autre [cs.OH]
RR-4396.pdf (2.61 Mo) Télécharger le fichier
inria-00072192 , version 1 (23-05-2006)
  • HAL Id : inria-00072192 , version 1
Fabien Gandon. Ontology Engineering: a Survey and a Return on Experience. RR-4396, INRIA. 2002. ⟨inria-00072192⟩
476 Consultations
1983 Téléchargements
