Averaging in Hamiltonian systems with slowly varying parameters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2002
Tewfik Sari
The aim of this paper is to describe the general averaging principle and to discuss the particular case of single-frequency systems, the case of systems with constant frequencies and the case of Hamiltonian systems. We show how the stroboscopic method, which is a method of the nonstandard perturbation theory of differential equations, can be used in this kind of problems. We give various examples which illustrate the simplicity and the effectiveness of the method.
Autre [cs.OH]
RR-4374.pdf (266.06 Ko) Télécharger le fichier
inria-00072214 , version 1 (23-05-2006)
  • HAL Id : inria-00072214 , version 1
Tewfik Sari. Averaging in Hamiltonian systems with slowly varying parameters. RR-4374, INRIA. 2002. ⟨inria-00072214⟩
72 Consultations
347 Téléchargements
