Optimal Risk Control under Excess of Loss Reinsurance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
We study the optimal reinsurance policy of an insurance company which gives part of its premium stream to another compagny in exchange of an obligation to support the difference between the amount of the claim and some retention level. This contract is known as excess of loss reinsurance. The objective of the insurance compagny is to maximize the expected utility of its reserve at some planning horizon and under a nonnegativity constraint. We suppose that reinsurance incurs a cost proportional to the size of risk run by the reinsurance compagny. We first prove existence and uniqueness results for this optimization problem by using stochastic control methods. In a second part, we solve the associated Bellman equation numerically by using an algorithm based on policy iterations.
RR-4317.pdf (833.14 Ko) Télécharger le fichier
inria-00072270 , version 1 (23-05-2006)
  • HAL Id : inria-00072270 , version 1
Mohamed Mnif, Agnès Sulem. Optimal Risk Control under Excess of Loss Reinsurance. [Research Report] RR-4317, INRIA. 2001. ⟨inria-00072270⟩
118 Consultations
116 Téléchargements
