A Comparison of Methods for Calculating the Matrix Block Source Term in a Double Porosity Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
Contaminant transport in a fractured porous medium can be modeled, under appropriate conditions, with a double porosity model. Such a model consists of a parabolic equation with a coupling term describing contaminant exchange between the fractures, which have high permeability, and the matrix block, which has low permeability. A locally conservative method based on mixed finite elements is used to solve the parabolic problem, and the calculation of the coupling term, which involves the solution of diffusion equations in the matrix blocks, is based on an analytic expression. Numerical experiment- s show that this analytic method for the coupling term compares favorably to several other methods.
Autre [cs.OH]
RR-4280.pdf (310.07 Ko) Télécharger le fichier
inria-00072307 , version 1 (23-05-2006)
  • HAL Id : inria-00072307 , version 1
Clarisse Alboin, Jérôme Jaffré, Patrick Joly, Jean Roberts, Christophe Serres. A Comparison of Methods for Calculating the Matrix Block Source Term in a Double Porosity Model. [Research Report] RR-4280, INRIA. 2001. ⟨inria-00072307⟩
138 Consultations
139 Téléchargements
