On the design of Multifiber WDM Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2001
Stéphane Pérennes
  • Fonction : Auteur
  • PersonId : 942945
A.W. Richa
  • Fonction : Auteur
Hervé Rivano
N. Stier
  • Fonction : Auteur
In this paper, we address multifiber optical networks with Wavelength Division Multiplexing (WDM). Assuming that the lightpaths use the same wavelength from source to destination, we extend the definition of the well-known Wavelength Assignment Problem (WAP), to the case where there are $k$ fibers per link, and $w$ wavelengths per fiber are available. We then develop a new model for the $(k,w)$-WAP, based on conflict hypergraphs- : Conflict hypergraphs more accurately capture the lightpath interdependencies- , generalizing the conflict graphs used for single-fiber networks. By relating the $(k,w)$-WAP with the hypergraph coloring problem, we prove that the former is \npc, and present further results with respect to the complexity of that problem. Finally, we analyze the practical performances of two methodologies based on hypergraph coloring, on existing backbone networks in Europe and in the USA. The first relies on an integer programming formulation and the second consists of a heuristic based on a randomized algorithm. We consider the two natural optimization problems that arise from the $(k,w)$-WAP : the problem of minimizing $k$ given $w$, and that of minimizing $w$ given $k$.
RR-4244.pdf (310.2 Ko) Télécharger le fichier
inria-00072343 , version 1 (23-05-2006)
  • HAL Id : inria-00072343 , version 1
A. Ferreira, Stéphane Pérennes, A.W. Richa, Hervé Rivano, N. Stier. On the design of Multifiber WDM Networks. RR-4244, INRIA. 2001. ⟨inria-00072343⟩
142 Consultations
73 Téléchargements
