s'authentifier
version française rss feed
inria-00072354, version 1
Computing the Diameter of a Point Set
Grégoire Malandain () 1, Jean-Daniel Boissonnat () 2
N° RR-4233 (2001)
Résumé : Given a finite set of points $\cal P$ in $\mathbb{R}^d$, the diameter of $\cal P$ is defined as the maximum distance between two points of $\cal P$. We propose a very simple algorithm to compute the diameter of a finite set of points. Although the algorithm is not worst-case optimal, it appears to be extremely fast for a large variety of point distributions.
  • Domaine : Informatique/Autre
  • Mots-clés : COMPUTATIONAL GEOMETRY / DIAMETER
  • Référence interne : RR-4233
  • inria-00072354, version 1
  • oai:hal.inria.fr:inria-00072354
  • Contributeur :
  • Soumis le : Mardi 23 Mai 2006, 20:30:34
  • Dernière modification le : Mercredi 31 Mai 2006, 14:24:26
tous les articles de la base du CCSd...
