A dual approach to semidefinite least-squares problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Matrix Analysis and Applications Année : 2004
In this paper, we study the projection onto the intersection of an affine subspace and a convex set and provide a particular treatment for the cone of positive semidefinite matrices. Among applications of this problem is the calibration of covariance matrices. We propose a Lagrangian dualization of this least-squares problem, which leads us to a convex differentiable dual problem. We propose to solve the latter problem with a quasi-Newton algorithm. We assess this approach with numerical experiments which show that fairly large problems can be solved efficiently.
sdls.pdf (251.45 Ko) Télécharger le fichier
inria-00072409 , version 1 (24-05-2006)
inria-00072409 , version 2 (25-03-2013)
Jérôme Malick. A dual approach to semidefinite least-squares problems. SIAM Journal on Matrix Analysis and Applications, 2004, 26 (1), pp.272-284. ⟨10.1137/S0895479802413856⟩. ⟨inria-00072409v2⟩
257 Consultations
1215 Téléchargements
