On circular Cylinders by Four or Five Points in Space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2001
Olivier Devillers
Franco P. Preparata
  • Fonction : Auteur
Philippe Trebuchet
  • Fonction : Auteur
  • PersonId : 833470
We are interested in computing effectively cylinders through 5 points, and in other problems involved in metrology. In particular, we consider the cylinders through 4 points with a fix radius and with extremal radius. For these different problems, we give bounds on the number of solutions and exemples show that these bounds are optimal. Finally, we describe two algebraic methods which can be used here to solve efficiently these problems and some experimentation results.
Autre [cs.OH]
RR-4195.pdf (430.62 Ko) Télécharger le fichier
inria-00072427 , version 1 (24-05-2006)
  • HAL Id : inria-00072427 , version 1
Olivier Devillers, Bernard Mourrain, Franco P. Preparata, Philippe Trebuchet. On circular Cylinders by Four or Five Points in Space. RR-4195, INRIA. 2001. ⟨inria-00072427⟩
181 Consultations
1413 Téléchargements
