Protocol Insecurity with Finite Number of Sessions is NP-complete - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2001
We investigate the complexity of the protocol insecurity problem for a finite number of sessions (fixed number of interleaved runs). We show that this problem is NP-complete in a Dolev-Yao model of intruders. The result does not assume a limit on the size of messages and supports non-atomic symmetric encryption keys. We also prove that in order to build an attack with a fixed number of sessions the intruder needs only to forge messages of polynomial size, provided that they are represented as dags.
Autre [cs.OH]
RR-4134.pdf (301.34 Ko) Télécharger le fichier
inria-00072492 , version 1 (24-05-2006)
  • HAL Id : inria-00072492 , version 1
Michaël Rusinowitch, Mathieu Turuani. Protocol Insecurity with Finite Number of Sessions is NP-complete. [Research Report] RR-4134, INRIA. 2001, pp.18. ⟨inria-00072492⟩
170 Consultations
352 Téléchargements
