On the Robustness of Interconnections in Random Graphs: A Symbolic Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
Philippe Flajolet
  • Fonction : Auteur
  • PersonId : 829512
Kostas Hatzis
  • Fonction : Auteur
Sotiris Nikoletseas
  • Fonction : Auteur
Paul Spirakis
  • Fonction : Auteur
Graphs are models of communication networks. This paper applies symbolic combinatorial techniques in order to characterize the interplay between two parameters of a random graph, namely its density (the number of edges in the graph) and its robustness to link failures. Here, robustness means multiple connectivity by short disjoint paths. We determine the expected number of ways to get from a source to a destination via two edge-disjoint paths of length $\ell$ in the classical random graph model $\G_n,p$. We then derive bounds on related threshold probabilities.
Autre [cs.OH]
RR-4069.pdf (461.28 Ko) Télécharger le fichier
inria-00072567 , version 1 (24-05-2006)
  • HAL Id : inria-00072567 , version 1
Philippe Flajolet, Kostas Hatzis, Sotiris Nikoletseas, Paul Spirakis. On the Robustness of Interconnections in Random Graphs: A Symbolic Approach. [Research Report] RR-4069, INRIA. 2000. ⟨inria-00072567⟩
55 Consultations
186 Téléchargements
