inria-00072671, version 1
A Portable and Efficient Communication Library for High-Performance Cluster Computing
Olivier Aumage 1Luc Bougé
a, 1Alexandre Denis
2Jean-François Méhaut 1Guillaume Mercier 1Raymond Namyst a, 1Loïc Prylli b, 1
N° RR-3976 (2000)
Résumé : This paper introduces Madeleine II, a new adaptive and portable multi-protoco- l communication library. Madeleine II has the ability to control multiple network protocols (BIP, SISCI, VIA) and multiple network adapters (Ethernet, Myrinet, SCI) within the same application session. Moreover, it includes advanced mechanisms to dynamically select the most appropriate transfer method for a given network protocol according to various parameters such as data size or responsiveness user requirements. We report on performance measurements obtained using BIP and SCI and we present preliminary results about our Nexus/Madeleine II and MPICH/Madeleine II ports.
- a – Ecole Normale Supérieure de Lyon - ENS Lyon
- b – CNRS
- 1 : REMAP (INRIA Rhône-Alpes / LIP Laboratoire de l'Informatique du Parallélisme)
- INRIA – École Normale Supérieure - Lyon – CNRS : UMR5668 – LIP
- 2 : Laboratoire de l'Informatique du Parallélisme (LIP)
- Université de Lyon – CNRS : UMR5668 – INRIA – École Normale Supérieure - Lyon – Université Claude Bernard - Lyon I
- Domaine : Informatique/Autre
- Mots-clés : MULTIPROTOCOL / MULTIPARADIGM / DYNAMICITY / NEXUS / MPI
- Référence interne : RR-3976
- inria-00072671, version 1
- http://hal.inria.fr/inria-00072671
- oai:hal.inria.fr:inria-00072671
- Contributeur : Rapport De Recherche Inria
- Soumis le : Mercredi 24 Mai 2006, 10:33:00
- Dernière modification le : Vendredi 23 Octobre 2009, 14:33:31
Documents associés
Exporter
