Algebraic Methods and Arithmetic Filtering for Exact Predicates on Circle Arcs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1999
Olivier Devillers
Bernard Mourrain
Monique Teillaud
The purpose of this paper is to present a new method to design exact geometric predicates in algorithms dealing with curved objects such as circular arcs. We focus on the comparison of the abscissae of two intersection points of circle arcs, which is known to be a difficult predicate involved in the computation of arrangements of circle arcs. We present an algorithm for deciding the $x$-order of intersections from the signs of the coefficients of a polynomial, obtained by a general approach based on resultants. This method allows the use of efficient arithmetic and filtering techniques leading to fast implementation as shown by the experimental results.
RR-3826.pdf (381.97 Ko) Télécharger le fichier
inria-00072832 , version 1 (24-05-2006)
  • HAL Id : inria-00072832 , version 1
Olivier Devillers, Alexandra Fronville, Bernard Mourrain, Monique Teillaud. Algebraic Methods and Arithmetic Filtering for Exact Predicates on Circle Arcs. RR-3826, INRIA. 1999. ⟨inria-00072832⟩
121 Consultations
147 Téléchargements
