The Support Splitting Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1999
Nicolas Sendrier
Two linear codes are permutation-equivalent if they are equal up to a fixed permutation of the codewords coordinates. We present here an algorithm able to compute this permutation. We introduce the concept of signature: a property of a position of a code such that the set of all signatures of a given code is globally invariant by permutation. To compute the permutati- on between two equivalent codes, one needs a signature which is both discrimin- ant and easy to compute. The weight enumerator of the hull of a code provides a signature which has such properties in most cases.
Autre [cs.OH]
RR-3637.pdf (356.82 Ko) Télécharger le fichier
inria-00073037 , version 1 (24-05-2006)
  • HAL Id : inria-00073037 , version 1
Nicolas Sendrier. The Support Splitting Algorithm. [Research Report] RR-3637, INRIA. 1999. ⟨inria-00073037⟩
152 Consultations
1779 Téléchargements
