A Finite Element Method for Domain Decomposition with Non-Matching Grids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1999
In this note we propose and analyse a new method for handling interfaces between non-matching grids based on an approach suggested by Nitsche [12] for the approximation of Dirichlet boundary conditions. The exposition is limited to self-adjoint elliptic problems, using Poisson's equation as a model. A priori and a posteriori error estimates are given, and we discuss the relation to the mortar finite element method. Some numerical results are included.
Autre [cs.OH]
RR-3613.pdf (438.15 Ko) Télécharger le fichier
inria-00073065 , version 1 (24-05-2006)
  • HAL Id : inria-00073065 , version 1
Roland Becker, Peter Hansbo. A Finite Element Method for Domain Decomposition with Non-Matching Grids. RR-3613, INRIA. 1999. ⟨inria-00073065⟩
136 Consultations
1016 Téléchargements
