Myrtle : A Set-Oriented Meta-Interpreter Driven by a «Relational» Trace for Deductive Databases Debugging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1999
Sarah Mallet
  • Fonction : Auteur
  • PersonId : 833594
Mireille Ducassé
Deductive databases manage large quantities of data and, in general, in a set-oriented way. The existing systems of explanation for deductive databases do not take these constraints into account. We propose a tracing technique which consists of integrating a "relational" trace and an instrument- ed meta-interpreter using substitution sets. The relational trace efficiently gives precise information about data extraction from the relational database. The meta-interpreter manages substitution sets and gives explanation on the deduction. The expensive aspects of meta-interpretation are reduced by the use of the trace which avoids many calculations. The flexibility of meta-interpretation is preserved. It allows different profiles of trace to be easily produced.
RR-3598.pdf (344.81 Ko) Télécharger le fichier
inria-00073081 , version 1 (24-05-2006)
  • HAL Id : inria-00073081 , version 1
Sarah Mallet, Mireille Ducassé. Myrtle : A Set-Oriented Meta-Interpreter Driven by a «Relational» Trace for Deductive Databases Debugging. [Research Report] RR-3598, INRIA. 1999. ⟨inria-00073081⟩
100 Consultations
152 Téléchargements
