Complexity Results on Election of Multipoint Relays in Wireless Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
Laurent Viennot
The election of multipoint relays allows to decrease the cost of broadcasting in wireless networks. For each source, the fewer elements the set has, the greater the gain is. In this paper, we prove that the computation of a multipoint relay set with minimal size is NP-complete. We also make the analysis of a heuristic proposed by A. Qayyum.
Autre [cs.OH]
RR-3584.pdf (202.74 Ko) Télécharger le fichier
inria-00073097 , version 1 (24-05-2006)
  • HAL Id : inria-00073097 , version 1
Laurent Viennot. Complexity Results on Election of Multipoint Relays in Wireless Networks. [Research Report] RR-3584, INRIA. 1998. ⟨inria-00073097⟩
149 Consultations
239 Téléchargements
