Models and Algorithms for the Collision of Rigid and Deformable Bodies
In this report, we describe models and algorithms designed to produce efficient and physically consistent dynamic simulations. These models and algorithms have been implemented in a unique framework, modeling both deformations and contacts through visco-elastic relations. Since this model of interaction (known as «penalty based») is much debated, we present a compared study of two contact models; «penalty» and «impulse». Indeed, the «penalty» based model is supposed to have two major drawbacks : - determin- ing the visco-elastic parameters and - choosing the computation time step. We present a solution for both problems based on physical concepts. Finally, we will present results comparing real data, «impulse» based simulation and «penalty» based simulation.
