Numerical Simulation of Aeroelastic Instabilities of Elementary Bridge Decks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
In this report, we propose a global methodology for the numerical simulation of wind effects on elementary bridge profiles, particularly possible aeroelast- ic instabilities. This methodology is based on an efficient coupling algorithm- , a finite-element solver for three-dimensional incompressible Navier-Stokes equations in a moving domain and a structural solver. The fluid solver is detailed, the emphasis being put on the ALE formulation. Numerical and experimental results are compared for cases with a structural rigid motion. On a rectangle, numerical simulations for forced oscillation (heaving or rotation) are qualitatively correct, rather inaccurate, but in good agreements with free oscillation numerical simulations though. On a H-shaped section close to the Tacoma Narrows bridge profile, numerical results are both qualitatively and quantitatively very satisfactory and promising.
RR-3549.pdf (1.8 Mo) Télécharger le fichier
inria-00073134 , version 1 (24-05-2006)
  • HAL Id : inria-00073134 , version 1
Serge Piperno. Numerical Simulation of Aeroelastic Instabilities of Elementary Bridge Decks. RR-3549, INRIA. 1998. ⟨inria-00073134⟩
138 Consultations
159 Téléchargements
