Further Results on Arithmetic Filters for Geometric Predicates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
Olivier Devillers
Franco P. Preparata
  • Fonction : Auteur
An efficient technique to solve precision problems consists in using exact computations. For geometric predicates, using systematically expensive exact computations can be avoided by the use of filters. The predicate is first evaluated using rounding computations, and an error estimation gives a certificate of the validity of the result. In this note, we studies the statistical efficiency of filters for cosphericity predicate with an assumption of regular distribution of the points.
Autre [cs.OH]
RR-3528.pdf (220.14 Ko) Télécharger le fichier
inria-00073157 , version 1 (24-05-2006)
  • HAL Id : inria-00073157 , version 1
Olivier Devillers, Franco P. Preparata. Further Results on Arithmetic Filters for Geometric Predicates. RR-3528, INRIA. 1998. ⟨inria-00073157⟩
78 Consultations
94 Téléchargements
