Large Deviation Principle for a Markov Chain with a Countable State Space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
Let E be a denumerable state space, X be an homogeneous Markov chain on E with kernel P. Then the chain X verifies a weak Sanov's theorem, i.e. a weak large deviation principle holds for the law of the pair empirical measure. In our opinion this is an improvement with respect to the existing literature since LDP in the Markov case requires in general, either E to be finite, or strong uniformity conditions, which important classes of chains do not verify, e.g. bounded jump networks. Moreover this LDP holds for any discrete state space Markov chain including non-ergodic chains.
Autre [cs.OH]
RR-3503.pdf (708.4 Ko) Télécharger le fichier
inria-00073182 , version 1 (24-05-2006)
  • HAL Id : inria-00073182 , version 1
Arnaud de La Fortelle, Guy Fayolle. Large Deviation Principle for a Markov Chain with a Countable State Space. [Research Report] RR-3503, INRIA. 1998. ⟨inria-00073182⟩
151 Consultations
535 Téléchargements
