Methods and Tools for Corporate Knowledge Management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
Olivier Corby
Alain Giboin
Myriam Ribière
  • Fonction : Auteur
This report presents a survey of some methods, techniques and tools aimed at managing corporate knowledge from a corporate memory (CM) designer's perspective. In particular, we analyze problems and solutions related to the following steps: detection of needs of CM, construction of the CM, its diffusion (specially using the Internet technologies), its use, its evaluation and its evolution.
Autre [cs.OH]
RR-3485.pdf (270.01 Ko) Télécharger le fichier
inria-00073203 , version 1 (24-05-2006)
  • HAL Id : inria-00073203 , version 1
Rose Dieng, Olivier Corby, Alain Giboin, Myriam Ribière. Methods and Tools for Corporate Knowledge Management. RR-3485, INRIA. 1998. ⟨inria-00073203⟩
249 Consultations
8497 Téléchargements
