Animated Image Compression in CATSERVER - Preliminary Description - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
A scalable moving image compression system is proposed for the CAT SERVER application, MPEG-like in its Group Of Frames structure for pre dictive coding but using supplementary information retained from previous images to help image prediction and a novel movement detection / coding scheme based on spanning points with associated motion vectors.
RR-3457.pdf (166.77 Ko) Télécharger le fichier
inria-00073233 , version 1 (24-05-2006)
  • HAL Id : inria-00073233 , version 1
Georges Gyory. Animated Image Compression in CATSERVER - Preliminary Description. [Research Report] RR-3457, INRIA. 1998. ⟨inria-00073233⟩
106 Consultations
77 Téléchargements
