On-line Scheduling in Assembly Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
The assembly system under consideration is composed with several machines, and some of these machines may be identical or able to perform the same operations. The manufacturing system is fully automated and, semi-finished products or components are not stored during the process. A limited flexibility exist since the manufacturing times can be extended within certain limits at the expense of the unavailability of the resource. There are no conflicts between the resources; in other words, the same machine cannot be used to perform different operations for a same product. Due to the intensity of the flow of products to be manufactured. It is not allowed to reschedule products which have been previously scheduled. Thus, when a new product requirement arrives in the system, we have to take advantage of the idle time windows. The goal is to complete the product as soon as possible. We give a real-time scheduling algorithm which guarantees an optimal makespan to any product which arrives in the assembly system. A numerical example is provided to illustrate this approach.
Autre [cs.OH]
RR-3395.pdf (681.1 Ko) Télécharger le fichier
inria-00073294 , version 1 (24-05-2006)
  • HAL Id : inria-00073294 , version 1
Fabrice Chauvet, Jean-Marie Proth. On-line Scheduling in Assembly Processes. [Research Report] RR-3395, INRIA. 1998, pp.14. ⟨inria-00073294⟩
52 Consultations
118 Téléchargements
