Efficient Dense Matching for Textured Scenes Using Region Growing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
We describe a simple and efficient dense matching method based on region growing techniques, which can be applied to a wide range of globally textured images. Our method can deal with non-rigid scenes and large camera motions. First a few highly distinctive features like points or areas are extracted and matched. These initial matches are then used in a correlation-based region growing step which propagates the matches in textured and more ambiguous regions of the images. The implementation of the algorithm is also given and is demonstrated on both synthetic and real image pairs.
Autre [cs.OH]
RR-3382.pdf (3.39 Mo) Télécharger le fichier
inria-00073307 , version 1 (24-05-2006)
  • HAL Id : inria-00073307 , version 1
Maxime Lhuillier. Efficient Dense Matching for Textured Scenes Using Region Growing. RR-3382, INRIA. 1998. ⟨inria-00073307⟩
110 Consultations
182 Téléchargements
