GCDS: A Compiler Strategy for Trading Code Size Against Performance in Embedded Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
In this paper we present GDS, a new approach for code optimization within the context of embedded systems. GDS applies several transformation sequences on each piece of code and chooses a posteriori the best trade-off between code size and performance, given the particular constraints. The proposed implementation relies on a modular framework that makes easy to handle differentcompilation strategies on the same piece of code.
Autre [cs.OH]
RR-3346.pdf (346.07 Ko) Télécharger le fichier
inria-00073343 , version 1 (24-05-2006)
  • HAL Id : inria-00073343 , version 1
François Bodin, Zbigniew Chamski, Christine Eisenbeis, Erven Rohou, André Seznec. GCDS: A Compiler Strategy for Trading Code Size Against Performance in Embedded Applications. [Research Report] RR-3346, INRIA. 1998. ⟨inria-00073343⟩
328 Consultations
317 Téléchargements
