Subspace-based Fault Detection and Isolation Methods - Application to Vibration Monitoring - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Michèle Basseville
Albert Benveniste
We address the problem of detecting and isolating faults modeled as changes in the eigenstructure of a linear dynamical system. The purpose of the paper is to describe and analyze new fault detection and isolation algorithms, based on recent stochastic subspace-based identification methods and the statistical local approach to the design of detection algorithms. The application to vibration monitoring of mechanical structures and rotating machines is discussed. A conceptual comparison is made with another detection algorithm based on the instrumental variables identification method, and previously proposed by two of the authors.
RR-3299.pdf (502.22 Ko) Télécharger le fichier
inria-00073389 , version 1 (24-05-2006)
  • HAL Id : inria-00073389 , version 1
Michèle Basseville, Maher Abdelghani, Albert Benveniste. Subspace-based Fault Detection and Isolation Methods - Application to Vibration Monitoring. [Research Report] RR-3299, INRIA. 1997. ⟨inria-00073389⟩
200 Consultations
472 Téléchargements
