Gröbner Bases, Symbolic Summation and Symbolic Integration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Frédéric Chyzak
The treatment of combinatorial expressions and special functions by linear operators is amenable to Gröbner basis methods. In this tutorial, we illustrate the applications of Gröbner bases to symbolic summation and integration.
Autre [cs.OH]
RR-3297.pdf (620.95 Ko) Télécharger le fichier
inria-00073391 , version 1 (24-05-2006)
  • HAL Id : inria-00073391 , version 1
Frédéric Chyzak. Gröbner Bases, Symbolic Summation and Symbolic Integration. [Research Report] RR-3297, INRIA. 1997. ⟨inria-00073391⟩
104 Consultations
207 Téléchargements
