Non-parametric Invariants and Application to Matching
This report present a non parametric matching method based on non parametric invariants to geometry and intensity transforms of images. The use of invariant makes it possible to match images under large geometric transforms. The use of non parametric measures makes it robust to partial occlusion. An algorithm to obtain sub-pixel precision is also shown. Results on real images validate the approach.
