Robust Location based Partial Correlation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
The visual correspondence problem is a major issue in computer vision. Correlation is a common tool for this problem. Most classical correlation methods fail near the disparity discontinuities, which occur at the boundaries of objects. In this paper, a {\em partial correlation} technique is proposed to solve this problem. Robust location methods are used to perform this partial correlation. Comparisons are made with other techniques and experimental results validate the approach.
Autre [cs.OH]
RR-3186.pdf (353.15 Ko) Télécharger le fichier
inria-00073503 , version 1 (24-05-2006)
  • HAL Id : inria-00073503 , version 1
Zhong-Dan Lan, Roger Mohr. Robust Location based Partial Correlation. [Research Report] RR-3186, INRIA. 1997. ⟨inria-00073503⟩
73 Consultations
174 Téléchargements
