An Efficient and Scalable Approach for Implementing Fault Tolerant DSM Architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
Christine Morin
Michel Banâtre
  • Fonction : Auteur
  • PersonId : 833460
Distributed Shared Memory (DSM) architectures are attractive to execute high performance parallel applications. Made up of a large number of components, these architectures have however a high probability of failure. We propose a protocol to tolerate node failures in two classes of DSM architectures: Cache Only Memory Architectures (COMA) and Distributed Virtual Shared Memory (SVM) systems. The proposed solution is based on backward error recovery and consists of an extension to the existing coherence protocols to manage data used by processors for the computation and recovery data, used for fault tolerance. The implementation of the protocol in a COMA architecture has been evaluated by simulation. The protocol has also been implemented in a \textscsvm system on a network of workstations. Both simulation results and measurements show that our solution is efficient and scalable.
RR-3103.pdf (138.09 Ko) Télécharger le fichier
inria-00073588 , version 1 (24-05-2006)
  • HAL Id : inria-00073588 , version 1
Christine Morin, Anne-Marie Kermarrec, Michel Banâtre. An Efficient and Scalable Approach for Implementing Fault Tolerant DSM Architectures. [Research Report] RR-3103, INRIA. 1997. ⟨inria-00073588⟩
386 Consultations
119 Téléchargements
