A Polynomial-Time Algorithm for Computing a Shortest Path of Bounded Curvature Amidst Moderate Obstacles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1996
Jean-Daniel Boissonnat
  • Fonction : Auteur
  • PersonId : 830857
Sylvain Lazard
In this paper, we consider the problem of computing a shortest path of bounded curvature amidst obstacles in the plane. More precisely, given prescribed initial and final configurations (i.e. positions and orientations) and a set of obstacles in the plane, we want to compute a shortest $C¨$ path joining those two configurations, avoiding the obstacles, and with the further constraint that, on each $C©$ piece, the radius of curvature is at least 1. In this paper, we consider the case of moderate obstacles (as introduced by Agarwal et al.) and present a polynomial-time exact algorithm to solve this problem.
Autre [cs.OH]
RR-2887.pdf (504.95 Ko) Télécharger le fichier
inria-00073803 , version 1 (24-05-2006)
  • HAL Id : inria-00073803 , version 1
Jean-Daniel Boissonnat, Sylvain Lazard. A Polynomial-Time Algorithm for Computing a Shortest Path of Bounded Curvature Amidst Moderate Obstacles. RR-2887, INRIA. 1996. ⟨inria-00073803⟩
84 Consultations
173 Téléchargements
