s'authentifier
version française rss feed
inria-00073859, version 1
Computing the Maximum Overlap of Two Convex Polygons Under Translations
Mark De Berg 1, Olivier Devillers (), Marc Van Kreveld, Otfried Schwarzkopf, Monique Teillaud ()
N° RR-2832 (1996)
Résumé : Let $P$ be a convex polygon in the plane with $n$ vertices and let $Q$ be a convex polygon with $m$ vertices. We prove that the maximum number of combinatorially distinct placements of $Q$ with respect to $P$ under translations is $O(n^2+m^2+\min(nm^2+n^2m))$, and we give an example showing that this bound is tight in the worst case. Second, we present an $O((n+m)\log(n+m))$ algorithm for determining a translation of $Q$ that maximizes the area of overlap of $P$ and $Q$. We also prove that the position which translates the centroid of $Q$ on the centroid of $P$ always realizes an overlap of 9/25 of the maximum overlap and that this overlap may be as small as 4/9 of the maximum.
  • Domaine : Informatique/Autre
  • Mots-clés : COMPUTATIONAL GEOMETRY / ARRANGEMENT / LOCALISATION
  • Référence interne : RR-2832
  • inria-00073859, version 1
  • oai:hal.inria.fr:inria-00073859
  • Contributeur :
  • Soumis le : Mercredi 24 Mai 2006, 13:55:42
  • Dernière modification le : Mercredi 31 Mai 2006, 14:24:28
tous les articles de la base du CCSd...
