Multifractional Brownian Motion : Definition and Preliminary Results - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
We generalize the definition of the fractional Brownian motion of exponent $H$ to the case where $H$ is no longer a constant, but a function of the time index of the process. This allows us to model non stationary continuous processes, and we show that $H(t)$ and $2-H(t)$ are indeed respectively the local Hölder exponent and the local box and Hausdorff dimension at point $t$. Finally, we propose a simulation method and an estimation procedure for $H(t)$ for our model.
RR-2645.pdf (758.37 Ko) Télécharger le fichier
inria-00074045 , version 1 (24-05-2006)
  • HAL Id : inria-00074045 , version 1
Romain-François Peltier, Jacques Lévy Véhel. Multifractional Brownian Motion : Definition and Preliminary Results. [Research Report] RR-2645, INRIA. 1995. ⟨inria-00074045⟩
1189 Consultations
3366 Téléchargements
