Ergodic Theorems for Stochastic Operators and Discrete Event Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 1998
We present a survey of the main ergodic theory techniques which are used in the study of iterates of monotone and homogeneous stochastic operators. It is shown that ergodic theorems on discrete event networks (queueing networks and/or Petri nets) are a generalization of these stochastic operator theorems. Kingman's subadditive ergodic Theorem is the key tool for deriving what we call first order ergodic results. We also show how to use backward constructions (also called Loynes schemes in network theory) in order to obtain second order ergodic results. We propose a review of systems entering the framework insisting on two models, precedence constraints networks and Jackson type networks
idempJER.pdf (427.81 Ko) Télécharger le fichier
inria-00074049 , version 1 (24-05-2006)
inria-00074049 , version 2 (27-07-2007)
  • HAL Id : inria-00074049 , version 2
François Baccelli, Jean Mairesse. Ergodic Theorems for Stochastic Operators and Discrete Event Networks. Cambridge University Press. Idempotency, Cambridge University Press, pp.171-208, 1998, Publications of the Newton Institute, 0 521 55344. ⟨inria-00074049v2⟩
Collections
INRIA INRIA2
138 Consultations
316 Téléchargements
