inria-00074101, version 1
3-D Vertical Ray Shooting and 2-D Point Enclosure, Range Searching, and Arc Shooting Amidst Convex Fat Objects
N° RR-2583 (1995)
Résumé : We present a new data structure for a set of $n$ convex simply-shaped fat objects in the plane, and use it to obtain efficient and rather simple solutions to several problems including (i) {\em vertical ray shooting} --- preprocess a set $\K$ of $n$ non-intersecting convex simply-shaped flat objects in 3-space, whose $xy$-projections are fat, for efficient vertical ray shooting queries, (ii) {\em point enclosure} --- preprocess a set $\Cn$ convex simply-shap- ed fat objects in the plane, so that the $k$ objects containing a query point $p$ can be reported efficiently, (iii) {\em bounded-size range searching} --- preprocess a set $\Cn$ convex fat polygons, so that the $k$ objects intersecting a `not-too-large' query polygon can be reported efficiently, and (iv) {\em bounded-size segment shooting} --- preprocess a set $\Cn (iii), so that the first object (if exists) hit by a `not-too-long' oriented query segment can be found efficiently. For the first three problems we construct data structures of size $O(\lambda_s(n) \log^3 n)$, where $s$ is the maximum number of intersections between the boundaries of the ($xy$-projections) of any pair of objects, and $\lambda_s(n)$ is the maximum length of $(n,s)$ Davenport-Schinzel sequences. The data structure for the fourth problem is of size $O(\lambda_s(n) \log^2 n)$. The query time in the first problem is $O(\log^4 n)$, the query time in the second and third problems is $O(\log^3 n + k \log^2 n)$, and the query time in the fourth problem is $O(\log^3 n)$. We also present a simple algorithm for computing a depth order for a set $\K$ as in (i), that is based on the solution to the vertical ray shooting problem. (A depth order for $\K$, if exists, is a linear order of $\K$, such that, if $K_1,K_2 \in \K$ and $K_1$ lies vertically above $K_2$, then $K_1$ precedes $K_2$.) The algorithm is able to determine whether such an order exists, unlike the algorithm of Agarwal~et~al. \cite{AgKS} that might output a false order when a depth order does not exist, and it is often more efficient in practical situations than the latter algorithm.
- 1 : PRISME (INRIA Sophia Antipolis)
- INRIA
- Domaine : Informatique/Autre
- Mots-clés : COMPUTATIONAL GEOMETRY / DATA STRUCTURES / OUTPUT-SENSITIVE ALGORITHMS / VISIBILITY
- Référence interne : RR-2583
- inria-00074101, version 1
- http://hal.inria.fr/inria-00074101
- oai:hal.inria.fr:inria-00074101
- Contributeur : Rapport De Recherche Inria
- Soumis le : Mercredi 24 Mai 2006, 14:31:47
- Dernière modification le : Mercredi 31 Mai 2006, 14:24:28
Documents associés
Exporter
