The Law of the Euler scheme for stochastic differential equations : I. convergence rate of the distribution function - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1994
Denis Talay
  • Fonction : Auteur
  • PersonId : 833429
We study the approximation problem of $\ee f(X_T)$ by $\ee f(X_T^n)$, where $(X_t)$ is the solution of a stochastic differential equation, $(X^n_t)$ is defined by the Euler discretization scheme with step $\fracTn$,and $f$ is a given function. For smooth $f$'s, Talay and Tubaro have shown that the error $\ee f(X_T)-f(X_T^n)$ can be expanded in powers of $\frac1n$, which permits to construct Romberg extrapolation procedures to accelerate the convergence rate. Here, we prove that the expansion exists also when $f$ is only supposed measurable and bounded, under an additional nondegeneracy condition of Hörmander type for the infinitesimal generator of $(X_t)$): to obtain this result, we use the stochastic variations calculus. In the second part of this work, we will consider the density of the law of $X_T^n$ and compare it to the density of the law of $X_T$. \noindent\bf AMS(MOS) classification: 60H07, 60H10, 60J60, 65C05, 65C20, 65B05
Autre [cs.OH]
RR-2244.pdf (308.49 Ko) Télécharger le fichier
inria-00074427 , version 1 (24-05-2006)
  • HAL Id : inria-00074427 , version 1
Vlad Bally, Denis Talay. The Law of the Euler scheme for stochastic differential equations : I. convergence rate of the distribution function. [Research Report] RR-2244, INRIA. 1994. ⟨inria-00074427⟩
186 Consultations
625 Téléchargements
