Mesh adaptation for compressible flows
We describe here some recent developments in mesh adaption for compressible viscous inviscid flow simulation. One of the most challenging task is to capture efficiently thin layers such as boundary layers, mixing layers. Two important issues, the coupling between mesh and flow, and the use of flat elements for stretching are considered in the case of deformation mesh systems.
