inria-00077007, version 1
Motion planning of legged robots : the spider robot problem
Jean-Daniel Boissonnat
1Olivier Devillers
1Franco P. Preparata 1Leonbattista Donati a, 2
N° RR-1767 (1992)
Résumé : We consider the problem of planning motions of a simple legged robot called the spider robot. The robot is modelled as a point where all its legs are attached, and the footholds where the robot can securely place its feet consist of a set of n points in the plane. We show that the space of admissible and stable placements of such robots has size Q (n2) and can be constructed in O ( n2 log n) time and O (n2) space. Once has been constructed, we can efficiently solve several problems related to motion planning.
- a – Brown University
- 1 : PRISME (INRIA Sophia Antipolis)
- INRIA
- 2 : Department of Computer Science (Brown University)
- Brown University
- Domaine : Informatique/Autre
- Référence interne : RR-1767
- inria-00077007, version 1
- http://hal.inria.fr/inria-00077007
- oai:hal.inria.fr:inria-00077007
- Contributeur : Rapport De Recherche Inria
- Soumis le : Lundi 29 Mai 2006, 11:49:37
- Dernière modification le : Mercredi 28 Février 2007, 16:46:37
Documents associés
Exporter
