Polymorphic typing of an algorithmic language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1992
Xavier Leroy
The polymorphic type discipline, as in the ML language, fits well within purely applicative languages, but does not extend naturally to the main feature of algorithmic languages : in-place update of data structures. Similar typing difficulties arise with other extensions of applicative languages : logical variables, communication channels, continuation handling. This work studies (in the setting of relational semantics) two new approaches to the polymorphic typing of these non-applicative features. The first one relies on a restriction of generalization over types (the notion of dangerous variables), and on a refined typing of functional values (closure typing). The resulting type system is compatible with the ML core language, and is the most expressive type systems for ML with imperative features proposed so far. The second approach relies on switching to "by-name" semantics for the constructs of polymorphism, instead of the usual "by-value" semantics. The resulting language differs from ML, but lends itself easily to polymorphic typing. Both approaches smoothly integrate non-applicative features and polymorphic typing.
Autre [cs.OH]
RR-1778.pdf (1.28 Mo) Télécharger le fichier
inria-00077018 , version 1 (29-05-2006)
  • HAL Id : inria-00077018 , version 1
Xavier Leroy. Polymorphic typing of an algorithmic language. [Research Report] RR-1778, INRIA. 1992. ⟨inria-00077018⟩
242 Consultations
1374 Téléchargements
