inria-00080566, version 2
Formalization of the neuro-biological models for spike neurons.
Lucas Ferro 1Charf-Eddin M'Sakni 1Pierre Repetto 1Nader Salman 1Manh-Tien Nguyen 1Thierry Viéville
1
N° RT-0324 (2006)
Résumé : When modelizing cortical neuronal maps (here spiking neuronal networks) within the scope of the FACETS project, researchers in neuro-science and computer-science use NeuroML, a XML language, to specify biological neuronal networks. These networks could be simulated either using analogue or event-based techniques. Specifications include : - parametric model specification - model equation symbolic definition - formalization of related semantic aspects (paradigms, ..) and they are used by "non-computer-scientists". In this context XML is used to specify data structures, not documents. The first version of NeuroML uses Java to map XML biological data which can be later simulated within GENESIS, NEURON, etc. The second version uses tools for handling XML data, as XSL, to transform an XML file. To allow NeuroML to be used intensively within the scope of the FACETS project, we will entirely analyse the software. First we are going to evaluate this software deeply in the Technical Report section. Then we will propose a prototype to write down NeuroML code easily.
- 1 : ODYSSEE (INRIA Sophia Antipolis)
- INRIA – Ecole des Ponts ParisTech – Ecole Normale Supérieure de Paris - ENS Paris
- Domaine : Informatique/Base de données
- Mots-clés : NeuroML – Biological Neurons – Spiking Neurons – Neural Networks Simulation
- Référence interne : RT-0324
- Versions disponibles : v1 (20-06-2006) v2 (24-07-2006)
- inria-00080566, version 2
- http://hal.inria.fr/inria-00080566
- oai:hal.inria.fr:inria-00080566
- Contributeur : Rapport De Recherche Inria
- Soumis le : Lundi 24 Juillet 2006, 14:53:28
- Dernière modification le : Mardi 30 Septembre 2008, 13:52:17
Documents associés
Exporter
