On the Pathwidth of Planar Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Fomin and Thilikos in [5] conjectured that there is a constant $c$ such that, for every $2$-connected planar graph $G$, {pw}(G^*) \leq 2\text{pw}(G)+c$ (the same question was asked simutaneously by Coudert, Huc and Sereni in [4]). By the results of Boedlander and Fomin [2] this holds for every outerplanar graph and actually is tight by Coudert, Huc and Sereni [4]. In [5], Fomin and Thilikos proved that there is a constant $c$ such that the pathwidth of every 3-connected graph $G$ satisfies: ${pw}(G^*) \leq 6\text{pw}(G)+c$. In this paper we improve this result by showing that the dual a 3-connected planar graph has pathwidth at most $3$ times the pathwidth of the primal plus two. We prove also that the question can be answered positively for $4$-connected planar graphs.
RRAHP06.pdf (136.49 Ko) Télécharger le fichier
inria-00082035 , version 1 (07-07-2006)
  • HAL Id : inria-00082035 , version 1
Omid Amini, Florian Huc, Stéphane Pérennes. On the Pathwidth of Planar Graphs. [Research Report] 2006, pp.6. ⟨inria-00082035⟩
124 Consultations
1164 Téléchargements
