CAESAR_SOLVE: A Generic Library for On-the-Fly Resolution of Alternation-Free Boolean Equation Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Radu Mateescu
  • Fonction : Auteur
  • PersonId : 834239
Boolean Equation Systems (BESs) provide a useful framework for modeling various verification problems on finite-state concurrent systems, such as equivalence checking and model checking. These problems can be solved on-the-fly (i.e., without constructing explicitly the state space of the system under analysis) by using a demand-driven construction and resolution of the corresponding BES. In this report, we present a generic software library dedicated to on-the-fly resolution of alternation-free BESs (i.e., without mutually recursive minimal and maximal fixed point equations). Four resolution algorithms are currently provided by the library: algorithms A1 and A2 are general, the latter being optimized to produce small-depth diagnostics, whereas algorithms A3 and A4 are specialized for handling acyclic and disjunctive/conjunctive BESs in a memory-efficient way. The library is developed within the CADP verification toolbox using the generic OPEN/CAESAR environment and is currently used for three purposes: on-the-fly equivalence checking modulo five widely-used equivalence relations, on-the-fly model checking of regular alternation-free mu-calculus, and on-the-fly reduction of state spaces based on tau-confluence.
RR-5948.pdf (336.61 Ko) Télécharger le fichier
inria-00084628 , version 1 (08-07-2006)
inria-00084628 , version 2 (18-07-2006)
  • HAL Id : inria-00084628 , version 2
Radu Mateescu. CAESAR_SOLVE: A Generic Library for On-the-Fly Resolution of Alternation-Free Boolean Equation Systems. [Research Report] RR-5948, INRIA. 2006, pp.38. ⟨inria-00084628v2⟩
256 Consultations
241 Téléchargements
