Combining typing and size constraints for checking the termination of higher-order conditional rewrite systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
In a previous work, the first author extended to higher-order rewriting and dependent types the use of size annotations in types, a termination proof technique called type or size based termination and initially developed for ML-like programs. Here, we go one step further by considering conditional rewriting and explicit quantifications and constraints on size annotations. This allows to describe more precisely how the size of the output of a function depends on the size of its inputs. Hence, we can check the termination of more functions. We first give a general type-checking algorithm based on constraint solving. Then, we give a termination criterion with constraints in Presburger arithmetic. To our knowledge, this is the first termination criterion for higher-order conditional rewriting taking into account the conditions in termination.
main.pdf (246.41 Ko) Télécharger le fichier
inria-00084837 , version 1 (05-09-2006)
inria-00084837 , version 2 (11-09-2006)
Frédéric Blanqui, Colin Riba. Combining typing and size constraints for checking the termination of higher-order conditional rewrite systems. 13th International Conference on Logic for Programming, Artificial Intelligence and Reasoning - LPAR 2006, Nov 2006, Phnom Penh, Cambodia. ⟨10.1007/11916277_8⟩. ⟨inria-00084837v2⟩
109 Consultations
142 Téléchargements
