Stability and Sensitivity Analysis for Optimal Control Problems with a First-order State Constraint having (nonessential) Touch Points - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
The paper deals with an optimal control problem with a scalar first-order state constraint and a scalar control. In presence of (nonessential) touch points, the arc structure of the trajectory is not stable. We show how to perform a sensitivity analysis that predicts which touch points will, under a small perturbation, become inactive, remain touch points or switch into boundary arcs. The main tools are the study of a quadratic tangent problem and the notion of strong regularity. The results can be interpreted as an extension of the shooting algorithm to the case when touch points occur for first-order state constraints. An illustrative example is given.
fo-rr2.pdf (612.66 Ko) Télécharger le fichier
inria-00087573 , version 1 (25-07-2006)
inria-00087573 , version 2 (26-07-2006)
  • HAL Id : inria-00087573 , version 2
J. Frederic Bonnans, Audrey Hermant. Stability and Sensitivity Analysis for Optimal Control Problems with a First-order State Constraint having (nonessential) Touch Points. [Research Report] 2006, pp.34. ⟨inria-00087573v2⟩
370 Consultations
128 Téléchargements
