Formal Verification of Concurrent Systems via Directed Model Checking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Sara Gradara
  • Fonction : Auteur
  • PersonId : 834673
Antonella Santone
  • Fonction : Auteur
  • PersonId : 834674
Maria Luisa Villani
  • Fonction : Auteur
  • PersonId : 834675
Model checking suffers from the state explosion problem, due to the exponential increase in the size of a finite state model as the number of system components grows. Directed model checking aims at reducing this problem through heuristic-based search strategies. The model of the system is built while checking the formula and this construction is guided by some heuristic function. In this line, we have defined a structure-based heuristic function operating on processes described in the Calculus of Communicating Systems (CCS), which accounts for the structure of the formula to be verified, expressed in the selective Hennessy-Milner logic. We have implemented a tool to evaluate the method and verified a sample of well known CCS processes with respect to some formulae, the results of which are reported and commented.
SANTONE.pdf (217.52 Ko) Télécharger le fichier
inria-00089489 , version 1 (18-08-2006)
  • HAL Id : inria-00089489 , version 1
Sara Gradara, Antonella Santone, Maria Luisa Villani. Formal Verification of Concurrent Systems via Directed Model Checking. Automatic Verification of Critical Systems, Sep 2006, Nancy, France, pp.132-144. ⟨inria-00089489⟩
Collections
AVOCS06
50 Consultations
146 Téléchargements
