inria-00090667, version 1
Circular Separability of Polygons
Jean-Daniel Boissonnat
1Jurek Czyzowicz a, 2Olivier Devillers
b, 1Mariette Yvinec
1
Algorithmica 30, 1 (2001) 67--82
Résumé : Two planar sets are circularly separable if there exists a circle enclosing one of the set and whose open interior disk does not intersect the other set. This paper studies two problems related to circular separability. A linear-time algorithm is proposed to decide if two polygons are circularly separable. The algorithm outputs the smallest separating circle. The second problem asks for the largest circle included in a preprocessed, convex polygon, under some point and/or line constraints. The resulting circle must contain the query points and it must lie in the halfplanes delimited by the query lines.
- a – Université du Québec à Hull
- b – INRIA
- 1 : PRISME (INRIA Sophia Antipolis)
- INRIA
- 2 : Departement d'Informatique
- Université du Québec à Hull
- Domaine : Informatique/Géométrie algorithmique
- Commentaire : http://www.springerlink.com/content/8q2b1bpn222a30hw/
- inria-00090667, version 1
- http://hal.inria.fr/inria-00090667
- oai:hal.inria.fr:inria-00090667
- Contributeur : Olivier Devillers
- Soumis le : Vendredi 1 Septembre 2006, 16:05:47
- Dernière modification le : Vendredi 1 Septembre 2006, 16:07:03
Documents associés
Exporter
