inria-00098669, version 1
Optimal Succinct Representations of Planar Maps
Luca Castelli Aleardi 1, 2Olivier Devillers
a, 2Gilles Schaeffer 1
Proc. 22th Annu. ACM Symposium on Computational Geometry (2006)
Résumé : This paper addresses the problem of representing the connectivity information of geometric objects using as little memory as possible. As opposed to raw compression issues, the focus is here on designing data structures that preserve the possibility of answering incidence queries in constant time. We propose in particular the first optimal representations for 3-connected planar graphs and triangulations, which are the most standard classes of graphs underlying meshes with spherical topology. Optimal means that these representations asymptotically match the respective entropy of the two classes, namely 2 bits per edge for 3-connected planar graphs, and 1.62 bits per triangle or equivalently 3.24 bits per vertex for triangulations.
- a – INRIA
- 1 : Laboratoire d'informatique de l'école polytechnique (LIX)
- CNRS : UMR7161 – Polytechnique - X
- 2 : GEOMETRICA (INRIA Sophia Antipolis)
- INRIA
- Domaine : Informatique/Géométrie algorithmique
- inria-00098669, version 1
- http://hal.inria.fr/inria-00098669
- oai:hal.inria.fr:inria-00098669
- Contributeur : Olivier Devillers
- Soumis le : Lundi 25 Septembre 2006, 18:59:37
- Dernière modification le : Mardi 26 Septembre 2006, 09:55:27
Documents associés
Exporter
