A Registry of Standard Data Categories for Linguistic Annotation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
In this paper we describe the most recent work within ISO TC37/SC 4, and in particular the development of a Data Category Registry (DCR) component of the Linguistic Annotation Framework. The DCR will contain a formally defined set of linguistic categories in common use within the language engineering community for reference and use in linguistically annotated resources. We outline the first proposals for creation and management of the DCR, as a solicitation for input from the community.
Autre [cs.OH]
A04-R-549.pdf (267.25 Ko) Télécharger le fichier
inria-00099858 , version 1 (13-01-2009)
  • HAL Id : inria-00099858 , version 1
Nancy Ide, Laurent Romary. A Registry of Standard Data Categories for Linguistic Annotation. 4th International Conference on Language Resources and Evaluation - LREC'04, 2004, Lisbonne, Portugal, pp.135-138. ⟨inria-00099858⟩
285 Consultations
98 Téléchargements
