Point-based Dynamic Programming for DEC-POMDPs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Daniel Szer
  • Fonction : Auteur
  • PersonId : 830433
We introduce point-based dynamic programming (DP) for decentralized partially observable Markov decision processes (DEC-POMDPs), a new discrete DP algorithm for planning strategies for cooperative multi-agent systems. Our approach makes a connection between optimal DP algorithms for partially observable stochastic games, and point-based approximations for single-agent POMDPs. We show for the first time how relevant multi-agent belief states can be computed. Building on this insight, we then show how the linear programming part in current multi-agent DP algorithms can be avoided, and how multi-agent DP can thus be applied to solve larger problems. We derive both an optimal and an approximated version of our algorithm, and we show its efficiency on test examples from the literature.
aaai2006.pdf (103.08 Ko) Télécharger le fichier
inria-00104443 , version 1 (06-10-2006)
  • HAL Id : inria-00104443 , version 1
Daniel Szer, François Charpillet. Point-based Dynamic Programming for DEC-POMDPs. 21st National Conference on Artificial Intelligence - AAAI'2006, Jun 2006, Boston/USA. ⟨inria-00104443⟩
99 Consultations
119 Téléchargements
